Specifications
General
Weight |
750 g (26.5 oz.) |
Water resistance |
IEC 60529 IPX7 (front of stereo only, when properly installed) |
Operating temperature range |
From 0 to 50°C (from 32 to 122°F) |
Storage temperature range |
From -20 to 70°C (from -4 to 158°F) |
Input voltage |
From 10.8 to 16 Vdc |
Current (max.) |
15 A |
Current (muted) |
Less than 900 mA |
Current (off) |
Less than 200 mA |
Fuse |
15 A mini blade-type |
NMEA 2000® LEN @ 9 Vdc |
1 (50 mA) |
Bluetooth® wireless range |
Up to 10 m (30 ft.) |
ANT® wireless range |
Up to 3 m (10 ft.) |
Wireless frequencies/protocols |
Wi‑Fi® 2.4 GHz @ +15 dBm nominal Bluetooth 2.4 GHz @ +10 dBm nominal ANT 2.4 GHz @ +4 dBm nominal |
Compass-safe distance |
15 cm (5.9 in.) |
On-board, Class D Amplifier
Output music power per channel |
4 x 70 W max. 2 ohm |
Total output peak power |
280 W max. |
Output power per channel 1 |
4 x 43 W RMS at 14.4 Vdc input, 2 ohm, 10% THD 4 x 26 W RMS at 14.4 Vdc input, 4 ohm, 10% THD |
Line output level (max.) |
5.5 V (peak to peak) |
Aux input level (typical) |
1 V RMS |
Tuner frequencies
Tuner |
Europe and Australasia |
USA |
Japan |
FM radio frequency range |
87.5 to 108 MHz |
87.5 to 107.9 MHz |
76 to 95 MHz |
FM frequency step |
50 kHz |
200 kHz |
50 kHz |
AM radio frequency range |
522 to 1620 kHz |
530 to 1710 kHz |
522 to 1620 kHz |
AM frequency step |
9 kHz |
10 kHz |
9 kHz |
