Indstilling af LED-lys til at reagere på musik
Indstilling af LED-lys til at reagere på musik kan medføre, at lyset blinker med forskellige intervaller. Konsulter din læge, hvis du har epilepsi eller er følsom over for skarpt lys eller blinklys.
Before you can set connected LED lights to react to music playing on the stereo, you must use a connected chartplotter to associate a light or group of lights with an audio zone on this stereo. See the chartplotter owner's manual for complete instructions.
- Select .
- Select Lygter, and select the lights or group of lights you want react to music.
Select AudioSync, and select an option:
If you want the lights to react to the intensity of the music playing, select Farveblanding.
Hvis du ønsker, at lyset skal reagere på bas- og diskantfrekvenserne i musikken, der spilles, skal du vælge Lydspektrum.
You must use a connected chartplotter if you want to change the colors used by this feature. See the chartplotter owner's manual for complete instructions.
