Turning on LED Light Effects
Valg af visse LED-lyseffekter kan medføre, at lysene blinker med forskellige intervaller. Konsulter din læge, hvis du har epilepsi eller er følsom over for skarpt lys eller blinklys.
The Garmin Spectra™ lighting controller has a selection of preprogrammed lighting effects that you can turn on using the stereo.
- Select .
- Select Lygter and select the lights or group of lights you want to use a lighting effect.
- Select Effekter and select one of the preprogrammed lighting effects to start it on the connected lights.
Overordnet emne: LED-belysningsstyring
