Constant Power Cable
The Constant Power Cable is an always-on, 12V power adapter that connects to the OBD II port in your vehicle. The device can power up to two dash cameras for a selected length of time after you turn off your vehicle.
For more information, or to purchase a Constant Power Cable, go to garmin.com.
Getting Started
When installing the device in a vehicle, you must install the device securely so it does not interfere with the vehicle operating controls, such as the foot pedals, or the driver's feet. Interference with the vehicle operating controls or feet can result in an accident, which could result in property damage, personal injury, or death.
If you notice any change in engine performance after connecting the device, disconnect the device immediately and contact Garmin® product support. Do not use the device if it affects engine performance or acceleration in your particular make and model of vehicle. Issues with engine performance or acceleration could result in an accident, leading to property damage, personal injury, or death.
Defer to your vehicle's warranty provisions and owner's instructions for guidance on whether any OBD II connector product might void or alter your vehicle's warranty. Garmin is not responsible for any costs or expenses associated with vehicle repairs or voided warranties.
Installing the Device
Time Switch
The time switch sets the length of time the device continues to supply power after you exit the vehicle. The device reenables power when it detects motion, or when you reenter and restart the vehicle.
10m |
10 minutes |
24h |
24 hours |
Always on |
If you want the device to remain off until you reenter the vehicle, you should select the 10m option.
If you want the device to operate continuously while the vehicle is parked, you should select the
24h or
option.
Status LED
The status LED shows the device status.
Status LED Activity |
Status |
Red |
The device is supplying power to the connected devices. |
Flashing red |
The timer has expired and the device is no longer supplying power to the connected devices. |
Off |
The device is receiving less than 12 V of power. The low battery protection feature turns off the device to protect the vehicle battery. |
Specifications
Operating temperature |
From -20° to 45°C (from -4° to 113°F) |
Input |
From 12 to 16 V, 1.6 A Max. |
Output |
5 Vdc, 1.5 A each (3.0 A total) |
Low battery protection voltage |
12 V |
