Adjusting the Backlight Brightness
Extensive use of screen backlighting can significantly reduce battery life. You can adjust the backlight brightness to maximize the battery life.
NOTE: The backlight brightness may be limited when the battery is low.
  1. Select Power.
  2. Use the slider bar to adjust the backlight brightness.
The device may feel warm when the backlight setting is high.
GUID-AA041605-DE53-4A18-B076-5DCB8D4F9007 v4
March 2026
