Map
Bearing pointer represents your location on the map. As you travel, the icon moves and leaves a track log. Waypoint names and symbols appear on the map. When you are navigating to a destination, your route is marked with a line on the map.
When the map orientation is Track Up, objects on the map appear to rotate around your position. As you travel, the entire map reorients in the direction you are facing. You can stabilize the objects by setting the orientation to North Up (Map Settings).
To open the map, select Map.
GUID-AA041605-DE53-4A18-B076-5DCB8D4F9007 v4
March 2026
