Position Format Settings
NOTE: You should not change the position format or the map datum coordinate system unless you are using a map or chart that specifies a different position format.
Select Tools symbol > System > Units > Position Format.
Position Format
Sets the position format in which a location reading appears.
Map Datum
Sets the coordinate system on which the map is structured.
Map Spheroid
Shows the coordinate system the device is using. The default coordinate system is WGS 84.
GUID-AA041605-DE53-4A18-B076-5DCB8D4F9007 v4
March 2026
