Replacing the Collar Strap
Before you replace the collar strap, you must remove all dirt, water, and debris from the device (Cleaning the Device).
  1. Pull the collar strap out of the GPS antenna, antenna guide, and the dog device.
    You may need to push and pull the collar strap to properly remove it. You may need to loosen the screw on the GPS antenna case, but do not remove them.
  2. Thread the new collar strap through the dog device, antenna guide, and GPS antenna.
  3. If necessary, tighten the screws that secure the GPS antenna case.
GUID-AA041605-DE53-4A18-B076-5DCB8D4F9007 v4
March 2026
