Changing the Dog ID
Before you can change the dog ID, the collar must be turned on and within range of the handheld device.
If you are experiencing interference from other collars or handheld devices in the area, you might need to change the ID for the dog.
  1. Select Dog List.
  2. Select a dog.
  3. Select Menu > Change ID.
  4. Select an available ID.
If another handheld device is tracking this dog, for best results, remove the dog from the device, and use the track and control codes to add the dog again (Adding a Dog Using the Track and Control Codes).
GUID-AA041605-DE53-4A18-B076-5DCB8D4F9007 v4
March 2026
