Customizing the Favorite Bar
You can add menu items or applications to the favorites bar that appears at the bottom of the home screen.
  1. From the main menu, select Tools symbol > Main Menu > Favorites.
  2. Select an option:
    • To add a new menu item to the list, select Add Page, select a category, and select the item.
    • To move a menu item, select a menu item, and select Move Up or Move Down.
    • To delete a menu item from the list, select a menu item, and select Remove.
    • To replace an item in the list after you have removed it, select Insert, and select a category.
    NOTE: The first menu item or application in the favorites bar displays on the home screen when the device turns on.
GUID-AA041605-DE53-4A18-B076-5DCB8D4F9007 v3
October 2024
