Using the Hard Keys for Training Adjustments
Before you can use this feature, you must customize your training keys with dog training commands (Customizing the Training Keys).
You can access and adjust training commands using the device's hard keys.
  1. From any screen, press the training up and down keys until the command page you want to adjust appears.
  2. Press the training enter key to select the command page.
  3. Use the training up and training down keys to highlight the training command you want to change, and press the training enter key.
  4. Select the command mode, and press the training enter key.
  5. If necessary, use the training up and down keys to adjust the command setting.
  6. Press the training enter key to return to the previous screen.
GUID-AA041605-DE53-4A18-B076-5DCB8D4F9007 v3
October 2024
