Activating the Device
WARNING
Before you can use the inReach® features of your Alpha® 300i device, including messaging, SOS, tracking, and inReach Weather, you must activate it.
  1. From your computer or smartphone, go to explore.garmin.com to create an account and activate a service plan.
  2. Turn on the device.
  3. Select Activate.
  4. Follow the on-screen instructions.
    NOTE: You must enter the device IMEI number and authorization code to complete the online portion of activation before you go outdoors.
  5. Go outdoors to an open area with a clear view of the sky, and point the antenna on the device toward the sky for optimal performance.
  6. Wait while the device communicates with the Iridium® satellite network.
    NOTE: It may take up to 20 minutes to activate your device. The device must send and receive several messages, which takes longer than sending a single message during regular use. Your device should remain outdoors until activation completes.
GUID-AA041605-DE53-4A18-B076-5DCB8D4F9007 v3
October 2024
