Adding a Contact Using Wireless Pairing
Before you can add a contact wirelessly, you should be near the contact's handheld device.
  1. Select Dog List > Contacts.
  2. Select an option:
    • On your handheld device select Add > Pair Handheld, and follow the on-screen instructions.
    • To add a contact by receiving the information from the contact's handheld device, select Add > Receive from Handheld.
  3. After successfully adding the contact, enter the name of the contact, and select Check.
The contact is added to your handheld device.
You can repeat this procedure using another hunter's handheld device to add your contact ID to that device.
GUID-AA041605-DE53-4A18-B076-5DCB8D4F9007 v3
October 2024
