Speaker Wire Gauge Guide
You should use
16 AWG (1.3
through 1.5 mm2) oxygen-free copper (OFC) speaker wire. You can use these tables to determine if you need to use a larger gauge of wire. These tables account for terminal connection resistance.
Do not use copper-clad aluminum (CCA) wire for this installation. CCA wire is more prone to breaking and its use could also result in poor product performance.
Distance between the amplifier and speaker |
Wire gauge |
From 0 to 28 ft. (from 0 to 8.5 m) |
16 AWG (1.3 through 1.5 mm2) |
From 28 to 69 ft. (from 8.5 to 21 m) |
12 AWG (3 through 4 mm2) |
Wire gauge |
From 0 to 14 ft. (from 0 to 4 m) |
From 14 to 35 ft. (from 4 to 10.5 m) |
Parent Topic: Wiring the Speaker
