Changing Your Tee Box Level
A tee box level is automatically assigned to you during initial setup based on your age. You can manually change the tee level, or disable the feature.
  1. Hold Top button.
  2. Select Settings > Golf Settings > Forward Tees.
  3. Select a tee level.
    NOTE: Lower tee levels are closer to the hole down the fairway.
GUID-A699B5E3-A65C-4F44-B23C-C376C2891F3F v2
March 2026
