Customizing the Display Settings
  1. Hold Top button.
  2. Select Settings > System > Display.
  3. Turn Large Fonts on to increase the size of the text on the screen.
  4. Select Brightness to set the brightness level of the screen.
  5. Select General Use or During Activity.
  6. Select an option:
    • Select Timeout to set the length of time before the screen turns off.
    • Select Always On to keep the watch face data visible and turn down the brightness and background. This option impacts the battery and display life (About the AMOLED Display).
    • Select Gesture to turn on the screen by raising and turning your arm to look at your wrist.
    • Select Sensitivity to adjust the gesture sensitivity to turn on the display more or less often.
  7. Select During Sleep > Watch Face to choose a sleep watch face with minimal, dim settings or to keep the default watch face on during your sleep window.
    NOTE: Your sleep window is from 10:00 p.m. until 6:00 a.m.
GUID-A699B5E3-A65C-4F44-B23C-C376C2891F3F v2
March 2026
