Setting an Alert
  1. Press Top button.
  2. Select More activities symbol.
  3. Select an activity.
  4. Select Settings symbol.
  5. Select Alerts.
  6. Select an option:
    • Select Add New to add a new alert for the activity.
    • Select the alert name to edit an existing alert.
  7. If necessary, select the type of alert.
  8. Select a zone, enter the minimum and maximum values, or enter a custom value for the alert.
  9. If necessary, turn on the alert.
For event and recurring alerts, a message appears each time you reach the alert value. For range alerts, a message appears each time you exceed or drop below the specified range (minimum and maximum values).
GUID-A699B5E3-A65C-4F44-B23C-C376C2891F3F v2
March 2026
