Station Connection Considerations
This device can be set up in conjunction with other compatible Garmin® devices to work together as a station. When planning stations on your boat, observe these considerations.
  • Devices earlier than the GPSMAP® 8000 series and GPSMAP 8500 series cannot be used in a station.
  • Although it is not necessary, it is recommended that you install all of the devices you plan to use in one station near each other.
  • No special connections are necessary to create a station, as long as all of the devices are connected to the Garmin Marine Network (Garmin Marine Network Considerations).
  • Stations are created and modified using the device software. See the owner's manual provided with the device for more information.
GUID-A5780D3E-B2B0-4C60-8835-94BCF0D13E14 v5
January 2025
