Using the Saved App
You can use the saved app to view your saved locations and courses.
  1. From the watch face, press Upper-right button.
  2. Select Saved.
  3. Select a saved item.
  4. Select an option:
    • To navigate to the location, select Go To.
    • To navigate the course, select Do Course.
    • To navigate the course in reverse, select More > Do Course in Reverse.
    • To view location details, select More > Details.
    • To edit the location or course details, select More > Edit.
    • To view a list of ascents in the course, select More > View Climbs.
    • To show the course on the map, even when you are not navigating, select More > Show on Map.
    • To share the location or course with the Garmin Share feature, select More > Share (Garmin Share).
    • To delete the location or course, select More > Delete.
GUID-A315BE5B-E191-4238-9712-D9C368997ADB v8
June 2026
