Altimeter and Barometer Settings
From the watch face, hold Middle-left button, select Watch Settings > System > Altimeter & Barometer.
Calibrate
Manually calibrates the altimeter and barometer sensor.
Auto Cal.
Self-calibrates the sensor each time you use satellite systems.
Sensor Mode
Sets the mode for the sensor. The Auto option uses both the altimeter and barometer according to your movement. You can use the Altimeter Only option when your activity involves changes in altitude, or the Barometer Only option when your activity does not involve changes in altitude.
Elevation
Sets the units of measure for elevation.
Pressure
Sets the units of measure for pressure.
Barometer Plot
Sets the length of time to show on the graph for the barometer glance.
September 2026
