Setting an Alert
  1. From the watch face, press Upper-right button.
  2. Select Activities, and select an activity.
    NOTE: This feature is not available for all activities.
  3. Press Lower-left button, and select Activity Options.
  4. Select Alerts.
  5. Select an option:
    • Select Add New to add a new alert for the activity.
    • Select the alert name to edit an existing alert.
  6. If necessary, select the type of alert.
  7. Select a zone, enter the minimum and maximum values, or enter a custom value for the alert.
  8. If necessary, turn on the alert.
For event and recurring alerts, a message appears each time you reach the alert value. For range alerts, a message appears each time you exceed or drop below the specified range (minimum and maximum values).
GUID-A315BE5B-E191-4238-9712-D9C368997ADB v2
December 2024
