The Ideal Swing Tempo
You can achieve the ideal 3.0 tempo using different swing timings, for example, 0.7 sec./0.23 sec. or 1.2 sec./0.4 sec. Each golfer may have a unique swing tempo based on their ability and experience. Garmin® provides six different timings.
The device displays a graph that indicates if your backswing or downswing times are too fast, too slow, or just right for the selected timing.
Swing tempo information with callouts
Callout number 1
Timing choices (backswing to downswing time ratio)
Callout number 2
Backswing time
Callout number 3
Downswing time
Callout number 4
Your tempo
Green
Good timing
Blue
Too slow
Red
Too fast
To find your ideal swing timing, you should start with the slowest timing and try it for a few swings. When the tempo graph is consistently green for both your backswing and downswing times, you can move up to the next timing. When you find a timing that is comfortable, you can use it to achieve more consistent swings and performance.
GUID-A315BE5B-E191-4238-9712-D9C368997ADB v2
December 2024
