Creating and Using a Power Guide
Before you can create a power guide, you must pair a power meter with your watch (Pairing Your Wireless Sensors). You must also have a course loaded to your watch (Creating a Course on Garmin Connect ).
You can also create a power guide in the Garmin Connect™ app.
  1. From the watch face, press Upper-right button.
  2. Select an outdoor biking activity.
  3. Hold Middle-left button.
  4. Select Training > Power Guide > Create New.‍
  5. Select a course (Courses).
  6. Select a riding position.
  7. Select a gear weight.
  8. Press Upper-right button, and select Use Plan.
    TIP: You can preview the map, elevation plot, effort, settings, and splits. You can also adjust the effort, terrain, riding position, and gear weight before you start riding.
GUID-A315BE5B-E191-4238-9712-D9C368997ADB v2
December 2024
