Starting an Expedition
You can use the Expedition activity to prolong the battery life while recording a multi-day activity.
  1. From the watch face, press Upper-right button.
  2. Select Activities > Outdoor > Expedition.
  3. Press Upper-right button to start the activity timer.
    The device enters low power mode and collects GPS track points once an hour. To maximize battery life, the device turns off all sensors and accessories, including the connection to your smartphone.
Recording a Track Point Manually
During an expedition, track points are recorded automatically based on the selected recording interval. You can manually record a track point at any time.
  1. During an expedition, press Upper-right button.
  2. Select Add Point.
Viewing Track Points
  2. Select View Points.
  3. Select a track point from the list.
  4. Select an option:
    • To start navigating to the track point, select Go To.
    • To view detailed information about the track point, select Details.
GUID-A315BE5B-E191-4238-9712-D9C368997ADB v8
June 2026
