Running Dynamics
Running dynamics is real-time feedback about your running form. Your fēnix® watch has an accelerometer to calculate five running form metrics. To view all of the running form metrics, you must pair your fēnix watch with the HRM 600, HRM‍-Fit™, HRM-Pro™ series accessory, or other running dynamics accessory that measures torso movement. For more information, go to garmin.com/performance-data/running.
Metric
Sensor Type
Description
Cadence
Watch or compatible accessory
Cadence is the number of steps per minute. It displays the total steps (right and left combined).
Stride length
Stride length is the length of your stride from one footfall to the next. It is measured in meters.
Vertical oscillation
Vertical oscillation is your bounce while running. It displays the vertical motion of your torso, measured in centimeters.
Vertical ratio
Vertical ratio is the ratio of vertical oscillation to stride length. It displays a percentage. A lower number typically indicates better running form.
Ground contact time
Ground contact time is the amount of time in each step that you spend on the ground while running. It is measured in milliseconds.
NOTE: Ground contact metrics are not available while walking.
Ground contact time balance
Compatible accessory only
Ground contact time balance displays the left/right balance of your ground contact time while running. It displays a percentage. For example, 53.2 with an arrow pointing left or right.
Step speed loss
HRM 600 only
Step speed loss is how much you slow down when your foot hits the ground while running. It is measured in centimeters per second. A lower number is typically better, as it indicates you have to do less propulsive work to speed back up.
NOTE: Step speed loss metrics are not available while walking.
Step speed loss percentage
HRM 600 only
Step speed loss percent is how much you slow down when your foot hits the ground as a percentage of your running speed. This accounts for step speed loss typically increasing with faster running speed.
GUID-A315BE5B-E191-4238-9712-D9C368997ADB v8
June 2026
