Heart Rate Accessory Running Pace and Distance
The HRM 600, HRM‍-Fit™, and HRM-Pro™ series accessories calculate your running pace and distance based on your user profile and the motion measured by the sensor on every stride. The heart rate monitor provides running pace and distance when GPS is not available, such as during treadmill running. You can view your running pace and distance on your compatible fēnix® watch when connected using ANT‍+® technology or secure Bluetooth® technology. You can also view it on compatible third-party training apps.
The pace and distance accuracy improves with calibration.
Automatic calibration
The default setting for your watch is Auto Calibrate. The heart rate accessory calibrates each time you run outside with it connected to your compatible fēnix watch.
NOTE: Automatic calibration does not work for indoor, trail, or ultra run activities (Tips for Recording Running Pace and Distance).
Manual calibration
You can select Calibrate & Save after a treadmill run with your connected heart rate accessory (Calibrating the Treadmill Distance).
  • Update your fēnix watch software (Product Updates).
  • Complete several outdoor runs with GPS and your connected HRM 600, HRM‍-Fit, or HRM-Pro series accessory. It's important that your outdoor range of paces matches your range of paces on the treadmill.
  • If your run includes sand or deep snow, go to the sensor settings, and turn off Auto Calibrate.
  • If you previously connected a compatible foot pod using ANT‍+ technology, set the foot pod status to Off, or remove it from the list of connected sensors.
  • Complete a treadmill run with manual calibration (Calibrating the Treadmill Distance).
  • If automatic and manual calibrations don't seem accurate, go to the sensor settings, and select HRM Pace & Distance > Reset Calibration Data.
    NOTE: You can try turning off Auto Calibrate, and then manually calibrate again (Calibrating the Treadmill Distance).
September 2026
