Display and Brightness Settings
From the watch face, hold Middle-left button, and select Watch Settings > Display & Brightness. You can also customize these settings for different situations, such as sleep and activities (Focus Modes).
Brightness
Sets the brightness level of the screen.
Always On Display
Sets the watch face data to remain visible and turn down the brightness and background. This option impacts the battery and display life (About the AMOLED Display).
Watch Face Seconds
Sets how often the watch face seconds appear when the Always On Display setting is turned on. This option impacts the battery and display life (About the AMOLED Display).
Text Size
Adjusts the size of the text on the screen.
Color Shift
Turns the screen to shades of red, green, or orange so that you can use the watch in low light conditions and help preserve your night vision or reduce eye strain. You can select Mode > Blue Light Filter to reduce the amount of blue light emitting from the watch. You can select Schedule to set the timing of the filters, such as Before Sleep Start.
Wake On Alert
Turns on the screen when you receive a notification or alert.
Wake On Gesture
Turns on the screen when you raise and turn your arm to look at your wrist.
Timeout
Sets the length of time before the screen turns off.
Touch
Enables the touchscreen. You can select Map Only to enable the touchscreen only on the map screen.
Touch Lock
Locks the touchscreen after the screen turns off. When this setting is enabled, you can swipe down to unlock the touchscreen.
GUID-A315BE5B-E191-4238-9712-D9C368997ADB v8
June 2026
