Recording a Bouldering Activity
You can record routes during a bouldering activity. A route is a climbing path along a boulder or small rock formation.
  1. From the watch face, press Upper-right button.
  2. Select Activities > Outdoor > Bouldering.
  3. Select a grading system.
    NOTE: The next time you start a bouldering activity, the watch uses this grading system. You can scroll down, select the activity settings, and select Grading System to change the system.
  4. Select the difficulty level for the route.
  5. Press Upper-right button to start the route timer.
  6. Start your first route.
  7. Press Lower-right button to finish the route.
  8. Select an option:
    • To save a successful route, select Completed.
    • To save an unsuccessful route, select Attempted.
    • To delete the route, select Discard.
  9. When you are done resting, press Lower-right button to start your next route.
  10. Repeat this process for each route until your activity is complete.
  11. After your last route, press Upper-right button to stop the route timer.
  12. Select Save.
GUID-A315BE5B-E191-4238-9712-D9C368997ADB v8
June 2026
