Editing a Countdown Event
  1. Select an option:
    • From the watch face, hold Middle-left button.
    • From the watch face, press Upper-right button.
    • Hold Upper-left button.
    TIP: You can also view your countdown events in the glances list (Customizing the Glances List).
  2. Select Clocks > Countdowns.
  3. Select a countdown event.
  4. Press Upper-right button, and select Set as Favorite to show the countdown event in the glances list (optional).
  5. Press Upper-right button, and select Edit Countdown.
  6. Select an option to edit:
    • To rename the event, select Name.
    • To change the date, select Date.
    • To change the time, select Time.
    • To change the icon, select Icon.
    • To add an abbreviated name for the event, select Abbreviation.
    • To add an event location, select Location.
    • To add event reminders, select Reminders.
    • To repeat the event every year, select Repeat Annually.
    • To remove the event, select Delete Countdown.
September 2026
