Managing Maps
  1. From the watch face, hold Middle-left button.
  2. Select Watch Settings > Map & Navigation > Map Manager.
  3. Select an option:
Downloading Maps with Outdoor Maps+
Before you can download maps to your device, you must connect to a wireless network (Connecting to a Wi‑Fi Network).
  2. Select Watch Settings > Map & Navigation > Map Manager > Outdoor Maps+.
  3. If necessary, press Upper-right button, and select Check Subscription to activate your Outdoor Maps+ subscription for this watch.
    NOTE: Go to garmin.com/outdoormaps for information about purchasing a subscription.
  4. Select Add Map, and select a location.
    A preview of the map region appears.
  5. From the map, complete one or more actions:
    • Drag the map to view different areas.
    • Pinch or spread two fingers on the touchscreen to zoom in and out of the map.
    • Select Zoom in and Zoom out to zoom in and out of the map.
  6. Press Lower-right button, and select Check mark.
  7. Select Edit.
  8. Select an option:
    • To edit the map name, select Name.
    • To change the map layers to download, select Layers.
      TIP: You can select More information to view details about the map layers.
    • To modify the map region, select Selected Area.
  9. Select Check mark to download the map.
    NOTE: To prevent battery drain, the watch queues the map download for later, and the download starts when you connect the watch to an external power source.
Downloading TopoActive Maps
  2. Select Watch Settings > Map & Navigation > Map Manager > TopoActive Maps > Add Map.
  3. Select a map.
  4. Press Upper-right button, and select Download.
Deleting Maps
You can remove maps to increase the available device storage.
    • Select TopoActive Maps, select a map, press Upper-right button, and select Remove.
    • Select Outdoor Maps+, select a map, press Upper-right button, and select Delete.
GUID-A315BE5B-E191-4238-9712-D9C368997ADB v10
November 2026
