Customizing the Controls Menu
You can add, remove, and change the order of the shortcut menu options in the controls menu (Controls).
  1. Hold Upper-left button to open the controls menu.
  2. Hold Middle-left button.
  3. Select an option:
    • To add a control to the menu, select Add Controls, and select a control to add.
    • To change the location of a shortcut in the controls menu, select Reorder Controls, select a control to move, press Middle-left button or Lower-left button to move the control to a new position, and press Upper-right button to select the new location.
    • To remove shortcut from the controls menu, select Remove Controls, and select a control to remove.
GUID-A315BE5B-E191-4238-9712-D9C368997ADB v8
June 2026
