Adding Contacts
You can add up to 50 contacts to the Garmin Connect™ app. Contact emails can be used with the LiveTrack feature. Three of these contacts can be used as emergency contacts (Adding Emergency Contacts).
  1. From the Garmin Connect app, select Menu.
  2. Select Contacts.
  3. Follow the on-screen instructions.
After you add contacts, you must sync your data to apply the changes to your fēnix® device (Using the Garmin Connect App).
GUID-A315BE5B-E191-4238-9712-D9C368997ADB v8
June 2026
