PacePro Training
Many runners like to wear a pace band during a race to help achieve their race goal. The PacePro™ feature allows you to create a custom pace band based on distance and pace or distance and time. You can also create a pace band for a known course to optimize your pace effort based on elevation changes.
You can create a PacePro plan using the Garmin Connect™ app. You can preview the splits and elevation plot before you run the course.
Downloading a PacePro Plan from Garmin Connect
Before you can download a PacePro plan from Garmin Connect, you must have a Garmin Connect account (Garmin Connect).‍
  1. Select an option:
  2. Select Training & Planning > PacePro Pacing Strategies.
  3. Follow the on-screen instructions to create and save a PacePro plan.
  4. Select Sending data or Send to Device.
Creating a PacePro Plan on Your Watch
Before you can create a PacePro plan on your watch, you must create a course (Creating a Course on Garmin Connect ).
  1. From the watch face, press Upper-right button.
  2. Select Activities, and select an outdoor running activity.
  3. Scroll down to select Training > PacePro Plans > Create New.‍
  4. Select a course.
  5. Select an option:
    • Select Goal Pace, and enter your target pace.
    • Select Goal Time, and enter your target time.
    Scroll down to view your custom pace band and preview the splits.
  6. Press Upper-right button.
  7. Select an option:
    • Select Use Plan to start the plan.
    • Select Map to view the course on the map.
    • Select Delete to discard the plan.
Starting a PacePro Plan
Before you can start a PacePro plan, you must download a plan from your Garmin Connect account, or create a PacePro plan on your watch (Creating a PacePro Plan on Your Watch).
  2. Select an outdoor running activity.
  3. Scroll down to select Training > PacePro Plans.‍
  4. Select a plan.
    TIP: You can scroll down to preview the splits and elevation plot before you accept the PacePro plan.
  5. Press Upper-right button.
  6. Select Use Plan to start the plan.
  7. If necessary, select Check mark to enable course navigation.
  8. Press Upper-right button to start the activity timer.
    Screenshot of the PacePro feature with callouts
    1
    Target split pace
    2
    Current split pace
    3
    Completion progress for the split
    4
    Distance remaining in the split
    5
    Overall time ahead of or behind your target time
    TIP: You can hold Middle-left button, and select Stop PacePro > Check mark to stop the PacePro plan. The activity timer continues running.
GUID-A315BE5B-E191-4238-9712-D9C368997ADB v10
November 2026
