Green Contours
With a Garmin Golf™ subscription, you can use Green Contour data to see the topography and slope of the green on compatible courses. When you reach the green, a heat map displays on your watch showing the direction and severity of the slopes. During a round, you can also press Upper-right button, and select Settings > Contour Shading to view the heat map. For more information on Green Contours, go to garmin.com/greencontours.
Heat Map Color
Slope Percentage
White
0%
Cyan
1%
Blue
2%
Green
3%
Yellow
4%
Orange
5%
Light red
6%
Red
7%
Pink
8% or higher
GUID-A315BE5B-E191-4238-9712-D9C368997ADB v10
November 2026
