Navigating to Your Starting Point During an Activity
You can navigate back to the starting point of your current activity in a straight line or along the path you traveled. This feature is available only for activities that use GPS.
  1. During an activity, press Upper-right button.
  2. Select Back to Start, and select an option:
    • To navigate back to the starting point of your activity along the path you traveled, select TracBack.
    • If you do not have a supported map or are using direct routing, select Route to navigate back to the starting point of your activity in a straight line.
    • If you are not using direct routing, select Route to navigate back to the starting point of your activity using turn-by-turn directions.
    Screenshot of the track to follow with callouts
    Your current location Callout number 1 and the track to follow Callout number 2 appear on the map.
GUID-A315BE5B-E191-4238-9712-D9C368997ADB v1
September 2024
