Using the Countdown Timer
  1. Select an option:
    • From the watch face, hold Middle-left button.
    • From the watch face, press Upper-right button.
    • Hold Upper-left button.
  2. Select Clocks > Timers.
  3. If you have never saved a timer, enter the time using the touchscreen or the Middle-left button and Lower-left button buttons.
  4. If you previously saved a timer, select an option:
    • To set a new countdown timer without saving it, select Quick Timer, and enter the time.
    • To set and save a new countdown timer, select Edit > Add Timer, and enter the time.
    • To set a saved countdown timer, select the saved timer.
  5. Press Upper-right button to start the timer.
  6. If necessary, select an option:
    • To stop the timer, select Pause.
    • To restart the timer, select Restart.
    • To cancel the timer, select Menu > Cancel Timer.
    • To save the timer, select Menu > Save Timer.
    • To automatically restart the timer after it expires, select Menu > Auto Restart > On.
    • To customize the timer notification, select Menu > Sound & Vibe.
September 2026
