Calibrating the Tack Assist
  1. From the watch face, select Upper-right button.
  2. Select Water Sports, and select Sail.
  3. Select Middle-left button or Lower-left button to view the tack assist screen.
    NOTE: You may need to add the tack assist screen to the data screens for the activity (Customizing the Data Screens).
  4. Select Upper-right button.
  5. Select an option:
    • To calibrate the starboard side, select Upper-right button.
    • To calibrate the port side, select Lower-left button.
    TIP: If the wind is coming from the starboard side of the vessel, you should calibrate starboard. If the wind is coming from the port side of the vessel, you should calibrate port.
  6. Wait while the device calibrates the tack assist.
    An arrow appears and indicates if your boat is being lifted or headed.
GUID-A315BE5B-E191-4238-9712-D9C368997ADB v1
September 2024
