Recording a Strength Training Activity
You can record sets during a strength training activity. A set is multiple repetitions (reps) of a single move.
  1. From the watch face, press Upper-right button.
  2. Select Activities > Gym > Strength.
  3. Select a workout.
  4. Press Lower-left button to view a list of workout steps (optional).
    TIP: While viewing workout steps, you can press Upper-right button and then press Lower-left button to view an animation of the selected exercise, if available.
  5. When you have finished viewing the workout steps, press Upper-right button, and select Do Workout.
  6. Press Upper-right button, and select Start Workout.
  7. Start your first set.
    The watch counts your reps. Your rep count appears when you complete at least four reps.
    TIP: The watch can only count reps of a single move for each set. When you want to change moves, you should finish the set and start a new one.
  8. Press Lower-right button to finish the set and move to the next exercise, if available.
    The watch displays the total reps for the set.
  9. If necessary, press Middle-left button or Lower-left button to edit the number of reps.
    TIP: You can also add the weight used for the set.
  10. If necessary, press Lower-right button when you are done resting to start your next set.
  11. Repeat for each strength training set until your activity is complete.
  12. After your last set, press Upper-right button, and select Stop Workout.
  13. Select Save.
GUID-A315BE5B-E191-4238-9712-D9C368997ADB v1
September 2024
