Navigating with Sight 'N Go
You can point the device at an object in the distance, such as a water tower, lock in the direction, and then navigate to the object.
  1. From the watch face, press Upper-right button.
  2. Select Map.
  3. Press Upper-right button.
  4. Select Navigate > Create a Course > Sight 'N Go.
  5. Select the activity you want to use while following the course.
  6. Point the top of the watch at an object, and press Upper-right button.
    Navigation information appears.
  7. Press Upper-right button to begin navigation.
GUID-A315BE5B-E191-4238-9712-D9C368997ADB v1
September 2024
