Using the inReach Remote
Before you can use the inReach® remote function, you must pair your inReach satellite communicator (Pairing Your Wireless Sensors), then add the inReach glance to the glances list (Customizing the Glances List).
- Turn on the inReach satellite communicator.
On your
fēnix® watch, press
from the watch face to view the inReach glance.
Press
to search for your inReach satellite communicator.
Press
to pair your inReach satellite communicator.
Press
, and select an option:
To send an SOS message, select Initiate SOS.
NOTE: You should only use the SOS function in a real emergency situation. -
To send a text message, select , select the message contacts, and enter the message text or select a quick text option.
To send a check-in message, select Send Check-in, and select a message from the list.
To view the timer and distance traveled during an activity, select Tracking.
Parent Topic: inReach Remote
