Garmin Pay
The Garmin Pay™ feature allows you to use your watch to pay for purchases in participating locations using credit, debit, or transit cards from a participating financial institution or transit card system.
NOTE: This feature is not available in all regions.
Setting Up Your Garmin Pay Wallet
You can add one or more participating credit, debit, or transit cards to your Garmin Pay wallet. Go to garmin.com/garminpay/banks to find participating financial institutions. Go to garmin.com/garminpay/transit to find participating transit systems.
  1. From the Garmin Connect™ app, select Menu.
  2. Select Wallet & Garmin Pay > Get Started.
  3. Follow the on-screen instructions.
Paying for a Purchase Using Your Watch
Before you can use your watch to pay for purchases, you must set up at least one payment card.
You can use your watch to pay for purchases in a participating location.
  1. Select an option:
    • From the watch face, press Upper-right button.
    • Hold Upper-left button.
  2. Select Wallet.
  3. Enter your four-digit passcode.
    NOTE: If you enter your passcode incorrectly three times, your wallet locks, and you must reset your passcode in the Garmin Connect app.
    Your most recently used payment card appears.
  4. If you have added multiple cards to your Garmin Pay wallet, press Lower-left button to change to another card (optional).
  5. Within 60 seconds, hold your watch near the payment reader, with the watch facing the reader.
    The watch vibrates and displays a check mark when it is finished communicating with the reader.
  6. If necessary, follow the instructions on the card reader to complete the transaction.
TIP: After you successfully enter your passcode, you can make payments without a passcode for 24 hours while you continue to wear your watch. If you remove the watch from your wrist or disable heart rate monitoring, you must enter the passcode again before making a payment.
Adding a Card to Your Garmin Pay Wallet
You can add up to 10 credit or debit cards to your Garmin Pay wallet.
  1. From the Garmin Connect app, select Menu > Wallet & Garmin Pay > Zoom in.
  2. Follow the on-screen instructions.
After the card is added, you can select the card on your watch when you make a payment.
Managing Your Garmin Pay Cards
You can temporarily suspend or delete a card.
NOTE: In some countries, participating financial institutions may restrict the Garmin Pay features.
  1. From the Garmin Connect app, select Menu > Wallet & Garmin Pay.
  2. Select a card.
  3. Select Menu.
  4. Select an option:
    • To temporarily suspend or unsuspend the card, select Suspend Card.
      The card must be active to make purchases using your fēnix® watch.
    • To delete the card, select Delete or Remove Card.
Changing Your Garmin Pay Passcode
You must know your current passcode to change it. If you forget your passcode, you must reset the Garmin Pay feature for your fēnix watch, create a new passcode, and reenter your card information.
  1. From the Garmin Connect app, select Menu.
  2. Select Wallet & Garmin Pay > Change Passcode.
The next time you pay using your fēnix watch, you must enter the new passcode.
GUID-A315BE5B-E191-4238-9712-D9C368997ADB v10
November 2026
