Customizing the Battery Saver Feature
The battery saver feature allows you to quickly adjust system settings to extend battery life in watch mode.
You can turn on the battery saver feature from the controls menu (Viewing the Controls Menu).
  1. Hold MENU.
  2. Select Settings > Power Manager > Battery Saver.
  3. Select Status to turn on the battery saver feature.
  4. Select Edit, and select an option:
    • Select Watch Face to enable a low-power watch face that updates once per minute.
    • Select Phone to disconnect your paired phone.
    • Select Activity Tracking to turn off all-day activity tracking, including steps, floors climbed, intensity minutes, sleep tracking, and Move IQ events.
    • Select Wrist Heart Rate to turn off the wrist heart rate monitor.
    • Select Backlight to disable the automatic backlight.
    The watch displays the hours of battery life gained with each setting change.
  5. Select During Sleep to enable the battery saver feature during your normal sleep hours.
    TIP: You can set your normal sleep hours in the user settings on your Garmin Connect™ account.
  6. Select Low Battery Alert to receive an alert when the battery is low.
Copyright © Garmin. All rights reserved.GUID-A298EB1C-21D9-430F-8D06-A2CC74E5D5E9 v4
