Setting an Alarm
You can set multiple alarms. You can set each alarm to sound once or to repeat regularly.
- From any screen, hold SET.
- Select Alarms.
- Enter the alarm time.
- Select Repeat, and select when the alarm should repeat (optional).
- Select Sounds, and select a type of notification (optional).
- Select to turn on the backlight with the alarm (optional).
- Select Label, and select a description for the alarm (optional).
Parent Topic: Clocks
