Manually Syncing Data with Garmin Connect NOTE: You can add options to the controls menu (Customizing the Controls Menu). Hold CTRL to view the controls menu. Select . Parent Topic: Garmin Connect
Manually Syncing Data with Garmin Connect NOTE: You can add options to the controls menu (Customizing the Controls Menu). Hold CTRL to view the controls menu. Select . Parent Topic: Garmin ConnectHomeConnected FeaturesGarmin ConnectManually Syncing Data with Garmin Connect
