Adding Contacts
You can add up to 50 contacts to the Garmin Connect™ app. Contact emails can be used with the LiveTrack feature.
Three of these contacts can be used as emergency contacts.
One phone number from your emergency contacts or an emergency services phone number, such as 911, can be used as your emergency calling number (Adding Emergency Contacts).
  1. From the Garmin Connect app, select Menu symbol or Menu symbol.
  2. Select Contacts.
  3. Follow the on-screen instructions.
After you add contacts, you must sync your data to apply the changes to your Venu® 2 Plus watch (Using the Garmin Connect App).
Copyright © Garmin. All rights reserved.GUID-A17FE8AC-DA32-4494-ABD1-AD1A388CC0C0 v4
