Specifications
Dimensions (W × H × D)
388.9 × 178.5 × 82.9 mm (15 5/16 × 7 × 3 1/4 in.)
Dimensions with cover on bail mount (W × H × D)
397.1 × 182.5 × 113.7 mm (15 5/8 × 7 3/16 × 4 7/16 in.)
Display size (W × H)
345.2 × 194.6 mm (13 5/8 × 7 11/16 in.)
369.1 mm (15 9/16 in.) diagonal
Display resolution
1920 × 720 pixels (IPS)
Weight
3.26 kg (7.2 lb.)
Compass-safe distance
50 cm (19.7 in.)
Max. power usage at 10 Vdc
56.93 W
Typical current draw at 12 Vdc
2.44 A
Max. current draw at 12 Vdc
4.31 A
Temperature range
From -15° to 55°C (from 5° to 131°F)
Material
Polycarbonate plastic and die-cast aluminum
Water rating
IEC 60529 IPX7 1
Input voltage
From 10 to 32 Vdc
Fuse
6 A, 125 V fast-acting
NMEA 2000® LEN @ 9 Vdc
2
NMEA 2000 draw
75 mA max.
USB connector
Micro-USB for compatible Garmin® card reader2
Wireless frequency
2.4 GHz @ 18.4 dBm maximum
Memory card
2 microSD® memory card slots, 32 GB max. card size, formatted to FAT32 or exFAT with speed class 10 or higher.
1 The device withstands incidental exposure to water of up to 1 m for up to 30 min. For more information, go to www.garmin.com/waterrating.
2 Only compatible Garmin card readers recommended. Third-party card readers are not guaranteed to be fully compatible.
GUID-9F62C8EE-C4A9-467C-859D-DE1771A877C8 v2
June 2025
