Showing and Hiding Map Data
If you have multiple maps installed on your device, you can choose the map data to show on the map.
  1. Press START.
  2. Select Map.
  3. Hold Menu symbol.
  4. Select the map settings.
  5. Select Map > Configure Maps.
  6. Select a map to activate the toggle switch, which shows or hides the map data.
GUID-9D99A9D4-467A-4F1A-A0EA-023184FEA3DD v9
June 2024
