Parts Bags
The installation hardware for the transducer is included in labeled bags. As you complete the installation process, each procedure begins with a reference to the label on the parts bag needed to complete the procedure. You can use this table to review or verify the parts bags needed for the installation procedures.
NOTE: You should leave all parts in the labeled bags until the instructions advise you to open a specific bag. Not all hardware is used for all installation types.
Bag label A
Contains parts needed when installing the side shaft mount
Bag label B
Contains parts needed when installing the barrel mount
Bag label C
Contains parts needed when installing the perspective, shaft, or barrel mount
Bag label D
Bag label E
Bag label F
Contains optional low-profile mounting screws
Bag label G
Contains optional longer screws for a shaft diameter greater than 42 mm (1.65 in.)
Bag label H
Contains an adapter disc needed when installing on a Force® Kraken trolling motor
Bag label J
Contains parts needed when installing the perspective mount
Bag label K
Contains an adapter disc needed when installing on the bottom shaft mount of a Spy Pole™ mount
GUID-9C83E43A-D15D-4D48-9AF6-AF0CBFA49D98 v4
October 2026
