General Settings
Select Menu button > SETTINGS.
NOTE: When a check box is filled, the option is on. When the check box is clear, the option is off.
DEVICE NAME
Sets a name for this device.
LANGUAGE
Sets the language used on the device.
TUNER REGION
Sets the region used by the FM and AM sources.
This setting is also needed to configure the DAB source.
TELEMUTE
Sets the behavior of the stereo when it detects a signal on the TELEMUTE wire in the wiring harness. This is commonly used to change to the Aux1 source when you hold the button on a handheld microphone. You can also choose to either mute the audio or change to the Aux1 source when connected to a hands-free mobile phone kit. See your handheld microphone or hands-free mobile phone kit instructions for more information.
NOTE: This setting does not affect a phone connected to the stereo using Bluetooth® technology.
POWER OPTIONS
Adjusts the power settings, such as POWER SAVE (Power Options).
ZONE
Enables you to configure the speaker zones (Speaker Zone Settings).
SOURCE
Allows you to enable, disable, and name the sources on the stereo (Source Settings) .
UPDATE
Updates the software on the stereo or connected devices using an update file on a connected USB flash drive (Update Options ).
NOTE: It is not necessary to use this menu if you are updating the software using the Garmin® Audio app on a mobile device instead of using an update file loaded onto a USB flash drive.
UPDATE > FACTORY RESET
Restores all settings to the factory default values.
ABOUT
Displays the software version information for the stereo and connected accessories.
GUID-9C4F8C97-D249-4CA6-9F9C-1919DCAF9A63 v1
September 2026
