Installing a Memory Card
WARNING
Do not use a sharp object to remove user-replaceable batteries.
You can install a microSD® memory card in the handheld device for additional storage or pre-loaded maps.
  1. Turn the D-ring counter-clockwise, and pull up to remove the cover.
  2. Remove the battery.
  3. Slide the card holder to the left and lift up.
    Back view of the device with the battery removed, showing memory card installation
  4. Place the memory card with the gold contacts facing down.
  5. Close the card holder.
  6. Slide the card holder to the right to lock it.
  7. Replace the battery and cover.
Copyright © Garmin. All rights reserved.GUID-9B02DCC5-9EBB-4B8A-A2A8-3E75FDC66D07 v1
